INFERNO4420
Hello, just downloaded IE8, and now, seemingly randomly, I can't access my Favorites from the altC or altA bar whatsoever.
even more odd, the Favorites folder has disappeared from My Documents (i reassiged the location to a backup drive previously, but that is still there).
when I try to bookmark something (ctrlD, or click add to favorites) absolutely nothing happens.. no popup, no nothing.
i've tried several things already from changing downloading the fix_fav_il prompt, to resetting folder properties, etc.
ah yes, and i tried uninstalling/reinstalling IE8 already, which didn't help anything
nothing seems to work..
I feel like if the Favorites folder would reappear in MyDocuments, I might be able to figure something out, but it just won't come back!
any help is appreciated, thanks!
