| Vista Home Premium 32 bit | Problem with running IE8 I installed IE8, but when I started it a window would come up and say "Internet explorer has stopped working". I searched for a problem and all I could find was that I needed a DEP compatible version of IE8. Can anyone help me please? |
| Vista Ultimate x64 SP2 | Re: Problem with running IE8 Try uninstall IE8 and reinstall using windows update. |
| Vista Home Premium 32 bit | Re: Problem with running IE8 Thanks CyberZues, I tried that and again a window came up saying "To help protect your computer Data Execution Prevention has closed internet explorer" So I had to uninstall again. Any ideas? |
| Vista Ultimate x64 SP2 | Re: Problem with running IE8 Do you have some add-ons for IE? If so, uninstall them and re-try... |
| Vista Home Premium 32 bit | Re: Problem with running IE8 I'm not sure what they would be.Are they in IE8? Where do I find them to uninstall? Thanks for your help. |
| | #6 (permalink) |
| Vista Ultimate x64 SP2 | Re: Problem with running IE8 They are usually in your installed apps in Control Panel |
| Problem running IMVU | Gaming | |||
| Problem running games | Gaming | |||
| Problem running games | Vista General | |||
| Problem running games | Vista Games | |||
| Problem running MyExposé... | Vista performance & maintenance | |||
