| Basic 32- Bit | Bridging Connection Problems Okay so this is my first post but I need some serious help. I usually hook up my 360 to my Dell Vista 32 Laptop and get Live through a bridged connection and then when I'm done I disable the bridge. But this time I right clicked the two connections and hit "Add to Bridge". So It when through the normal add to bridge thing, but when it completed an icon didnt show up saying network bridge and also I lost my internet it says connect when I go to connect to a wireless network but everywhere else it says I'm not connected. So I need some serious help. Thanks, Nicholas |
| Vista Home Premium 32bit | Re: Bridging Connection Problems can you post the ipconfig |
| Bridging all traffic from physical adapter to virtual adapter | Virtual Server | |||
| Issues with bridging between VPC and host OS network adapters | Virtual PC | |||
| Connection problems...PLEASE HELP!!! | Network & Sharing | |||
| IE 7 Connection problems & Windows Mail Connection | Vista General | |||
| Connection problems | Vista networking & sharing | |||
