Vista - ICS problem.
Old 06-21-2009   #1 (permalink)
Vista home premium 32bit.
ICS problem.
Ok my modem is connected to the computer through USB 2.0. It is working properly, I am on it right now typing this. It's a wired modem. Now when I try to ICS to hub it obviously doesn't recognize it because it says it's local only. How would I go about getting it to recognize that I want it to be an internet connection? (sorry if I sound a little hasty, but I have been on 270000 support lines and no one has helped me.)
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
