| 32bit | Multiple network connection problems I'm running the Vista 32bit on my Sony vaio laptop. I was able to connect to the internet thru wifi fine until recently and I'm not sure what happened. Now whenever I go to "connect to" to select a network, it selects the network just fine but that network shows up in my Network and Sharing Center as 2 totally seperate networks. When I try to gain online acess this causes an issue because after running the diagnostic tests I get a command to disable one of the active network connections. So when I try to do this on one connection it takes away both because they are the same. If anyone can give a little insight on this please let me know. |
| Network connection problems with vista 64 bit | Network & Sharing | |||
| Wireless Network Connection Problems | Vista networking & sharing | |||
| One way network connection problems | Virtual PC | |||
| Vista Network Connection and Upload problems | Network & Sharing | |||
| RC2 network connection problems to Internet | Vista General | |||
