| Vista Home Premium 32bit | Wireless on Medion Pc Not working Hi I re-installed windows yesterday on my Medion Pc as the computer would not load properly. So i used the recovery disc and re-installed it back to factory. Once this was done my wireless would not work...when you click on the connect to button then no wireless networks could be viewable for me to connect to. I have Vigin Broadband with a NetGear Router. I took the Pc to the router and did a wired connection which worked straight away as soon i connected the wire to both ends....so i installed all the softwares i needed and put the pc back but i do not have internet access. Please can you help me solve. Do i need to install the router onto the comp again or are there other drivers i may need? I did install the driver from Medion website. Thanks |
| vista home premium 32bit | Re: Wireless on Medion Pc Not working Hi b4nil Install your Wireless Network Card Drivers. |
| Vista Home Premium 32bit | Re: Wireless on Medion Pc Not working Do you know where i can get them from? Thanks Anil |
| vista home premium 32bit | Re: Wireless on Medion Pc Not working Hi b4nll You get all your Medion PC from Medion web site, or Windows update. |
| Dell Wireless WLAN Card Wireless Network Controller has stopped working | Network & Sharing | |||
| Wireless Card Driver(Wireless not working) | Network & Sharing | |||
| Medion Laptop and watching TV | Vista music pictures video | |||
| Medion 4394 Scanner VISTA | Vista installation & setup | |||
| medion Drivers | Vista General | |||
