Hi everyone,
I'm having a hell of a time connecting to the Internet on my living room computer. Right now, I'm connecting directly from the wall, however, I want to use my router so I can have a wired connection to my PS3 and XBOX 360 as well. This, in itself, is a feat because for the longest time, my connection would be intermittent, and even when I would ping using the command prompt, sometimes I would get 4 successful pings, sometimes the 2nd or 3rd (or both) would time out, sometimes I would get no ping. Then I (stupidly) messed with DNS settings and I can't get my network connection to work with the Internet. Can someone PLEASE help me!?
I know what's asked for at the start per the forums I've read is for the ipconfig /all results, so I'm pasting those below. Any help in getting me up on the Internet AND my Network would be much much much appreciated! Thank you! (PS-I know it's not my routers--I have a Belkin and a Linksys and I tested them on other computers and have had no problems with them up there).
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Ramtrap1>
Windows IP Configuration
Host Name . . . . . . . . . . . . : Hector
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : BelkinLivingRoom
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : BelkinLivingRoom
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 00-25-11-35-4A-85
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f1a8:e757:1818:6b0d%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, December 19, 2009 2:34:26 PM
Lease Expires . . . . . . . . . . : Sunday, December 20, 2009 2:34:26 PM
Default Gateway . . . . . . . . . : 192.168.1.10
DHCP Server . . . . . . . . . . . : 192.168.1.10
DHCPv6 IAID . . . . . . . . . . . : 167781649
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-11-FB-0E-1E-00-25-11-35-4A-85
DNS Servers . . . . . . . . . . . : 68.87.73.246
68.87.71.230
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
***Again, I'm connected directly to the wall right now, so you can't see my router, but I will say that I'm confused about the "BelkinLivingRoom" for the connection-specific DNS Suffix.
Please help!
Will
C:\Users\Ramtrap1>
68.87.71.230
Please help!
Will
