Impossible Wireless Internet Problem
7Simon
One day my house electricity went off and caused my router to shut off.When i turned back on my router i didnt have any wireless internet connect anymore. The only way i could connect to the internet now is through my modem using the ethernet cable.
I have used the diagnostic repair and even updated/reinstalled my internet driver, but it's still not working.
I don't know if it's the laptop or the wireless router that's the problem.
Can anybody please help?
I use a Dell Wireless 1395 WLAN Mini-Card
I have a Linksys Wireless-G 2.4GHz 802.11g Broadband Router
Is there power to the router when it is plugged in? If so, it sounds like you might need to hold down the "Reset" Button on the router for about 30 seconds.. Can you see other networks? Is your Wireless Switch light blue or amber?
Let me know if you get results from this.. If the router does not power on, then the router has been fried and you need to purchase a new router.
    Self-Built
    AMD PHENOM X4 9600 BE 2.3GHZ @ 2.46GHZ
    TA790GX 128M AM2+
    8GB OCZ PC6400 800MHZ DDR2 RAM
    NVIDIA GTS 250 1GB VRAM
    SB5120 24-BIT 7.1
    AOC 2330V 23" LCD
    1920x1080
    250GB SEAGATE HDD
    650W
    GENERIC
    3 120MM FANS
    MS WIRELESS DESKTOP 3000
    6MB/s
    Main Machine. Just upgraded my RAM to 8GB. Next task will be to get a new processor for this machine ( 9650 was for my secondary machine )
I have a similar problem with a Linksys WRT54G2V1 wireless router. I went on their Chat line and got the following procedure. I don't know if it applies in your case but here it is; This did not solve my problem I think because of a problem with IE8
Okay. Here are the steps:
1. Press the Reset button at the back of the router for 10 seconds while it is powered on. Then unplug it from power for 1 minute afterwards.
2. Plug the modem to the router's Internet port and plug the main computer to any of the router's numbered ports (the main computer is the one that can get online straight to the modem even without the router).
3. Open Internet Explorer browser, type 192.168.1.1 on the Address bar and hit the Enter key. Leave the User Name field blank and type admin on the Password field.
4. Go to the MAC Address Clone sub tab. Enable it then click Clone this PC's MAC. Click Save Settings.
from Zerabelle O. (10124) to All Participants:
5. Go to the Wireless tab. Set the Wireless Configuration to Manual. Change the SSID from 'linksys' to any name you want, enable the SSID Broadcast, then click on Save Settings.
6. Go to the Wireless Security sub tab. Set the Security Mode to WPA-Personal, enter a password (it should be at least 8 characters), then click Save Settings. That will then be your wireless password.
7. Turn off all devices (computer--router--modem) for 30 seconds. Then restart them (modem--router--computer). Wait for the router's power light to stay solid before you plug it to the modem, and connect the computers (wired and wirelessly) to the router.
Take note of the steps and ori it.
Or paste it to MS Word.
    ASUS P5VD2-VM (PCI EX 16, 6 Usb, Core 2 support) 2.20 Ghz
    Intel Core 2 DUO 2200 Processor 1 m cache
    DDR 11 Kingston 667, 2 Gig
    Intel 950
    High Definition Audio Device
    ACER 22 inch Wide LCD Flat Panel
    250 Gig Western Digital SATA 11
    ATX IN WIN tower Case
    400 watt Dual Fan power supply
    Logitech Multimedia Keyboard (wireless)
    Logitech Optical Mouse (wireless)
    Motorola Cable Modem
    D-Link Router DI 604
    Toshiba Satellite A10 laptop on network
