Vista wireless networking pains. Need help!
TSC17
I have literally spent all day researching forums, posts, blogs, and tech sheets trying to figure this out.
I have an HP dv9925nr notebook. Vista 64. Broadcom 4321AG adapter. SMCwgbr-14-N wireless router.
My XP laptop works fine in wireless mode.
My HP/Vista laptop just got back from surgery, was working in wireless mode on this connection before, but after a system restore it is not. When I first got it a year and a half ago I remember going through many pains to get this problem figured out, but now I can't remember what I did to fix it!
When I connect, I can't get onto more than a couple of websites before it stops working (although it still says that it's connected to the router).
I can connect it in wired mode to the router with no problems.
I verified that I have the latest driver for the wireless adapter.
I have all the latest updates from Windows.
Any suggestions that doesn't include buying Windows 7?
Thanks in advance.
Todd
Uninstall wireless adapter and then re-install in computer management. If it works fine. If it has trouble staying connected then the adapter is struggling to work properly, and will require a new one.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache
    1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Entertainment Keyboard 7000
    MS Wireless Laser mouse 8000
    1.2mb & 10mb
