Hey, I searched for a solution on the forums but couldn't find anything that worked
So I have an acer aspire with windows vista home premium, sky wireless broadband and a netgear N wireless adapter.
Lately my internet keeps disconnecting and i have to reset the modem and take out and reinsert the adapter to get it back, the other computer which is attached by wire works just fine even when i'm disconnected. It usually stays stable with low connection for a while but would randomly disconnect every now and then, very frustrating!
So far i've updated the drivers which had little to no effect and then i tried reinstalling it with the disc, also no effect. Calling Netgear is useless since my warranty is over and they put me on to some guy who trys to get £60 off me. It used to work just fine from the same location but then the computer downstairs got moved and it's been getting worse since even though i don't see how that's connected and the pc is now back where it was.
Anyway i'm pretty sure the issue is with the adapter, any advice on what i can do to fix this? could to be related to a windows update maybe?
- [email protected]
- [email protected]
- [email protected]
- Graphics Card(s)
- [email protected]
- [email protected]
- [email protected]
