You should upgrade or use an
alternative browser .
Solved need help in networking
hello frnds,
I have two desktop at my home. I want both to connect via LAN. I have broadband connection. what i have as hardware are:
1. Lan Card
2. Lan Cable
3. 8 port ethernet switch
i am ataching a image od all these hardware.
can i connect my both desktop with these hardware????
please guide me in detail.
Thanks in advance.
27.1 KB
10.7 KB
22.6 KB
19.1 KB
HP dv2519tu pavillion Laptop
1.50 GHz
Winstron
2.5 gig RAM
intel onboard
Conexant HD Smart Audio HD2
HP Brightview Display
1280X800
SATA - 160 + 500 GB
HP
HP Laptop
Air
HP Laptop
HP
4 MB/SEC-Download, 2 MB/SEC-Upload
Network Enthusiast
Yes it is Possible all you need to do is to Place the Network card into the PCI Card socket and then Connect the Ethernet from the Desktop to the Back of the Router and not the Modem (Blue)
Note
You are going to need 2 Ethernet cables to be able to connect both via LAN
Hope This Helps,
Josh
Intel Core i5 2400 @ 3.10GHz
Foxconn H67MP-S/-V/H67MP
8.0GB DDR3 @ 665MHz (2GBx4)
AMD HD Radeon 6870
SMB1930NW (1440x900@60Hz)
Novatech Night
Dell HID-compliant mouse
but i dont have router....only modem i have?
1.50 GHz
Winstron
2.5 gig RAM
intel onboard
1280X800
SATA - 160 + 500 GB
HP
HP Laptop
Air
HP Laptop
HP
Network Enthusiast
Are there any ethernet ports on the back of your modem?
AMD HD Radeon 6870
Novatech Night
only one ethernet port in my modem.
1.50 GHz
Winstron
2.5 gig RAM
intel onboard
1280X800
SATA - 160 + 500 GB
HP
HP Laptop
Air
HP Laptop
HP
Hewlett-Packard SR5019UK
M2N68-LA (Narra)
2.50GB
nVidia GeForce
Realtec ALC888 Audio
17" LCD Monitor
160 Gb Usable Hard Drive
Sorry just noticed the name Hytech (India).
You could contact them by their website, link below.
This includes all their products & information regarding connections and cables etc:-
Ethernet Switch-Hytech - Kaizen Computech
M2N68-LA (Narra)
2.50GB
nVidia GeForce
17" LCD Monitor
thanks frnds. finally with your help, i solved this problem.
thanks a lot.
1.50 GHz
Winstron
2.5 gig RAM
intel onboard
1280X800
SATA - 160 + 500 GB
HP
HP Laptop
Air
HP Laptop
HP
