unable to connect using wireless connection
capo
Since successfully restoring my laptop to factory settings I have been unable to connect using my Intel PRO/Wireless 3945ABG Network Connection.
Initially it worked, but after a while it stopped. I have completed several system restores, and the wireless connection works for a few days. On the last occasion (after installing windows updates) I received the dreaded blue screen and have been unable to connect.
On Saturday, my wireless connection suddenly starting working, 24 hours later it stopped.
I am not sure if it is related to installing new windows updates as prior to restoring to factory settings I had no issues with my wireless connection.
I am able to connect using the ethernet cable and I am currently able to connect using Pluscom wireless usb adapter.
I would be grateful for any suggestions as its driving my insane.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . :
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con
nection
Physical Address. . . . . . . . . : 00-1C-BF-5F-C6-9B
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 00-03-0D-84-69-82
Link-local IPv6 Address . . . . . : fe80::5d3e:14dd:2a75:953%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 03 May 2011 13:23:21
Lease Expires . . . . . . . . . . : 04 May 2011 13:23:21
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 134218509
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-4C-61-91-00-03-0D-84-69-82
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:2427:a1a:3f57:fffd(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::2427:a1a:3f57:fffd%14(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
If you are facing the slow connection issue, you can check the reason for the problem. If the connection drop issue is due to your ISP, you can contact your ISP. If you discover any issue from your side, you can check the router and the associated hardware. If you have issues with your Ethernet cables, you can replace them.
