oscillator
From Vista,a pppoe connection is created using the 'Get Connected wizard' or
rasphone.exe, it shows up as a 'Dial-up connection' in the network
connections folder. When you right click on the client connection created,
click on Properties, it says 'Connect using Modem '.
Is this a registry issue or what? How can I fix this?
