Danbury,CT.USA
vista home premium 32bit
Local Time: 10:20 PM
wired or wireless??
A few network questions ....
1. Is it better to be hard wired then wireless?? I get 300mb wireless n @ 2.4ghz and 100mb wired.I'm cunfused!!!
2.What is the advantage of duel channel 5mhz and 2.4mhz?? I get only fair coverage @5hmz and excellent coverage at 2.4mhz. I tried all the various settings Fair is the best I get.Did I waste my money??
My tv is hard wired...Any advantage to wireless @ 5 Mhz even at Fair signal? I get 125mb with a fair signal.
vista home premium
Re: wired or wireless??
I think the consensus is that hardwiring by CAT5 is the best for HD video such as blu-ray and AVCHD. If you don't want to string the wire, then you have to live with what you get.
Look at this for a discussion of the dual channel 5 Mhz-
New Zealand
Genuine Windows 7 Home Premium x64
Local Time: 02:20 PM
most electronics (microwaves cordless phones etc) use the 2.4ghz band and causes interference with wifi signals. 5GHz is not used by a range of electronics so less interference. 300mb is the advertised speed. the actuall speed is quite lower. BUT it should be slightly faster than 100mb wired. 1000mb (gigabit ethernet) is a different story. hope i helped in some way
System Manufacturer/Model Number Custom Gaming Rig 780G OS Genuine Windows 7 Home Premium x64 CPU AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3 Motherboard Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3 Memory 2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel Graphics Card HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz Sound Card Realtek HD Audio Monitor(s) Displays Dell E2311H DVI/VGA 5ms response, Full HD Screen Resolution 1920x1080 @ 60Hz
Keyboard Logitech K120 Wired Keyboard Mouse Logitech K120 Wired Mouse PSU Cooler Master Extreme Power Plus 700w Case Lian-Li PC-6010 With Side Window Cooling Aywun A4 80mm fan Hard Drives 320GB Seagate Barracuda 7200.02 SATA II Internet Speed 802.11B/G/N 17Mb/s Other Info AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
