how to reset network adapter settings without login to the operating system first?
Stuckfree
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Re: how to reset network adapter settings without login to the operating system first
What kind of adapter do you have- wireless card, etc.?
Why do you need to reset it?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
By default LAN or WLAN card has dynamic ip address after windows is installed, however i have set up a static ip address to my NIC card and can't log in to windows xp after 30 days grace so i need to reset NIC card to dynamic to activate windows xp.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
When you get the activation wizard does it not have the option of calling Microsoft to obtain the activation code?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Townsbg- I don't think I understand. He's trying to reset a network adapter.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
I think they are trying to activate windows XP after the 30 trial period with the static IP & cannot log-in?
Change the router address to match one for the PC connect by cable & go from there!
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Thanks lottiemansion-
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Yes it has the option as you mentioned, however i want to know how to reset a NIC card setting to dynamic without log in to windows first.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Hi there do you think it will work after changing the router default IP to something like 192.168.5.6. By default my ISP router IP address is 192.168.1.1
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
If you could describe your network set-up in more detail I could answer that.
So, if you are refering to an in-trim router & have set the gateway/ DNS to 192.168.1.1 on the 192.168.5.6 one, then it should, but more detail would help!
    40 Meg
