WiFi problems
alexgrindley666
I've been having problems connecting to WiFi from my laptop. When I connect to my home WiFi it says unidentified network and then there is a red cross between that and the internet.
It also says its a public network and the access is local only.
Can anyone help?
Did you use the correct password?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I had to ask.
You could try resetting your wifi adapter by unistalling it via the device manager. DO NOT DELETE THE DRIVER.
Then rescan for changes. It'll reinstall your adapter, then try to connect.
Can you access any wifi points?
Might want to try removing all your security on your router and try connecting. Possibly a security issue.
