You should upgrade or use an
alternative browser .
Solved Strange Wifi Problem - Your thoughts
My father's got an ASUS laptop with 8.1, a MacBook Pro, an ipad and a printer. In the last several months when he closes his ASUS and it goes to sleep wifi for his Macbook Pro and printer become unavailable but not his ipad. Any thoughts on what's going on? :huh:
Operating System
Vista Home Premium x64
Dell Inspiron 546
Sempron LE-1300
2GB DDR SDRAM 800MHZ-2X1GB DIM M
Integrated ATI Radeon HD3200
VIA High Definition Audio
Samsung 32" HDTV
1366 x 768
320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
Are you/he certain they are connected to the router and not through an Adhoc connection with the Asus?
Dual L5639 // i7 950 @ 4.0Ghz
gtx 560 ti // gtx 260-216
Dual 22" // Headless
What do you mean by an ad hoc connection? In terms of how we went about things, I believe he simply turned his new ASUS on and it gained connectivity.
Operating System
Dell Inspiron 546
Sempron LE-1300
Samsung 32" HDTV
1366 x 768
Technically it shouldn't have, unless you mean after the passwords etc.
Ad hoc means the Asus acts as a router. Id make sure all the stuff is directly connected to his router.
What's strange is that while his printer and Macbook lose their connectivity when the Asus is asleep, his ipad almost never has that problem. And this problem is pretty much recent; things worked initially.
Operating System
Dell Inspiron 546
Sempron LE-1300
Samsung 32" HDTV
1366 x 768
Yha, read that. I would get him to ensure they are properly connected. Can't hurt.
I just read something by someone who seemed to have a similar problem and he solved it by changing or fixing his router. And what do you mean by properly connected?
Thanks.
Operating System
Dell Inspiron 546
Sempron LE-1300
Samsung 32" HDTV
1366 x 768
Oh, just that the correct ssid and password.
Tried the Network Adapter Trouble shooter and that seems to have fixed the issue. Problem now is a known Macbook Pro issue where it loses the network connection after waking from sleep which is not a major problem. I'll have to try some of the known fixes or maybe a Genius Bar visit will do.
Thanks.
Operating System
Dell Inspiron 546
Sempron LE-1300
Samsung 32" HDTV
1366 x 768
