Vista - Force Resolution - Monitor Overclock
Old 09-19-2008   #1 (permalink)
Windows Vista™ Ultimate
Vista and NVidia are very restrictive about EDID and restrict available Monitor Resolutions, While ATI and NVidia have made options available for over-riding available resolution values...Some may find this resets or your real maximum resolution is completely unavailable
My "PnP Monitor" would get reset to 1024x768 every so often and was a pain in the *** to get the NVidia panel to force the proper resolution even though the NVidia control panel recognizes the display and names ir correctly...I found this Overclockers Article about removing two pins to remove EDID transmitted information...
I was shocked to find it does exactly what you want, It will allow you to set any resolution/refreshrate you want!
I dont recommend doing this on your monitor cable encase you permanently destroy your monitor cable!!!!!!
Go out and buy some DVI adapters... there less than $5!!
How to: Set whatever res I want to my monitor? (Disable Edid) - Overclock.net - Overclocking.net
Ok, the idea is if you isolate and remove the wires used for edid you will be able to set any res that your monitor can handle. (Edid: That annoying firmware in your monitor that tells your comp whether or not you can set a res. (To bypass it you usually need to be set manually in control center.))
What the mod does:
When you go to set a res your monitor it will no longer have a say in whether or not it wants to be set to that res...
Example: My monitor can easily do 2048x1536 but according to edid it is only supposed to go as high as 1856x1392.
It's kinda like overclocking your monitor.
Pull pins straight out with needle nose pliers
I am not responsible for any damages, you do this at your own risk.
Works best on vga crt's.
Old 09-19-2008   #2 (permalink)
Vista Ultimate x64
Re: Force Resolution - Monitor Overclock
lol wow.
Old 09-22-2008   #3 (permalink)
Windows 7 x64
Can this do any damage to your monitor, though? Even though I'm happy with 1680x1050, it's an interesting find.
Old 09-22-2008   #4 (permalink)
Quote  Quote: Originally Posted by Everlong18 View Post
Your monitor will turn off if it doesnt support the resolution your trying to set, Its protected from any damage
Im defiantly happy with the results of the mod though, I was able to up the resolution of my monitor and up the resolution used on a mates flatscreen tv while using high-def over DVI He was only able to use 1024x768 with HDTV until using this tweak
I just recommend using a seperate DVI adapter input plug so you dont **** your proper cable
Old 03-10-2009   #5 (permalink)
Vista Ultimate x64
WOW
AMAZING
I AM IN AWE
I have had a bad EDID problem from day with my monitor, tried everything to fix, spent hours with tech support and DIY troubleshooting. Posted in about 10 different forums to no avail.
Until I read your post....
Now, everything is changed
I can finally use my native resolution of 1920 x 1200!!!!
You did what nvidia and samsung could not do!
THANK YOU!
Old 07-21-2009   #6 (permalink)
Quote  Quote: Originally Posted by STRIKERIIXUSER View Post
WOW
AMAZING
I AM IN AWE
THANK YOU!
Your welcome
Sorry its taken ages to reply, I lost the notification e-mail and only saw a reply after trolling my UserCP
How to force a bigger screen resolution? Vista hardware & devices
Way to force monitor standby when resuming from sleep Vista hardware & devices
Monitor resolution Vista General
Force Monitor refresh rate Vista General
