| windows xp | how to disable acoustic mode in scsi hard disk is there anyone knows how to disable acoustic management in scsi hdd? appreciate your help! thanks in advance kianlie |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: how to disable acoustic mode in scsi hard disk Hi kianlie, This is a feature of some HDDs in order to make them quieter. Unfortunately, because they work by reducing the speed of the drive (according to load), they can make some systems run slow. There are utilities available to turn this feature on and off (where supported), but you will need to get these from the HDD manufacturer's website. |
| Windows - No Disk error after installing an external hard disk | Vista hardware & devices | |||
| New 2nd Hard Disk -visible in Disk Management - but NOT in Explorer/Computer | Vista hardware & devices | |||
| Sleep Mode does not power down hard disk | Vista General | |||
| removing scsi disk devices vista | Vista hardware & devices | |||
| How to disable full row select in details mode ? | Vista file management | |||
