Vista - Soak It to Me: Inside Liquid-Suspended Gaming PC
Old 12-13-2008   #1 (permalink)
Microsoft® Windows Vista™ Ultimate x64 SP2 Windows 7 7127 x64
Looking for a beefy gaming rig, and don't mind getting your hands a little wet? Hardcore Computer's Reactor might just be the 100-pound computational monolith for you.
Crafted from 2.5mm-thick aircraft aluminum and packed with powerful hardware, the Reactor is already a fairly striking and competitive machine. But there's a secret weapon sloshing around in that unassuming tank: four and a half gallons of cooling oil.
PC enthusiasts looking to get the most power out of their machines have often turned to overclocking — pushing key components to perform faster than the manufacturer intended. This generates quite a bit of heat, which is traditionally fought using an array of fans or a maze of tubes pumping cooling fluid to select components.
The Reactor takes the liquid-cooled principle a bit further by submerging everything into a tank of coolant. Of course, this isn't your average fish tank filled with mineral oil — take a look at the innards of this (relatively) mini-supercomputer.
Left: Behold, Hardcore Computer's Reactor. Like most gaming PCs, it's crammed with overclocked, high-performance hardware. But there's an important difference here: Every single component is submerged in a custom-designed cooling oil, called Core Coolant. Less trouble with heat means a faster, highly stable system. Dunking everything in fluid works surprisingly well, and is more efficient compared with traditional air- or water-cooling methods.
Old 12-13-2008   #2 (permalink)
Windows 7 x64
Re: Soak It to Me: Inside Liquid-Suspended Gaming PC
It's been done for a while now this sort of cooling, just this company are cashing in on the idea.
Old 12-15-2008   #3 (permalink)
Windows 7 x64 build 7100 & Ubuntu 9.04
That is so cool, but i would imagine changing hardware could be a real bitch....
~Lordbob
Pinnacle Liquid Software
Upgrade to Liquid Overclocking & Cooling
Windows Vista Ultimate 64-bit Gaming and Compatibility Gaming Gaming
[ANN] Liquid XML Studio 2009 SP1 Released .NET General
logon screen spilt liquid Vista General
