| Windows 7 x64 | PC Power Managment Program Came across this program, that seems quite useful: Edison PC Power Management Software | Edison It's a free program that can help cut energy costs with your PC. Tells you how much power your PC uses, gives advice how to cut down and how to balance the power usage and can save you money on your electricity and also remind you when your electricity goes in to off-peak hours. You just need to enter how much a kilowatt an hour costs you with your PC, and it'll give you a good estimation of how much you can save a year, and how much power your computer uses. |
| Vista x64 Ultimate | Re: PC Power Managment Program Why not shut down when not using it. Saves on electricity and cooling. |
| memory managment | .NET General | |||
| Process managment | PowerShell | |||
| advanced hard drive power managment | Vista hardware & devices | |||
| DVD-drive power managment | Vista hardware & devices | |||
| Disk Managment | Vista performance & maintenance | |||
