| Vista Ultimate 32 | CPU issue Hey well i just got my rig at christmas, the specs are in the sig thing, and well it's 2.1ghz tri core now so i wanted to OC it a little bit. i went to the bios and turned my FSB to 200 to 215, booted up windows and everything worked fine, so i opened CPU-Z and it was on 2.2ghz, but my cpu was making a noise louder then before, so i went back into the bios and checked the temps, it was 43.c from 40.c before the oc so the temps were fine , i reset the fsb to 200 and the noise went away, i dont know if this is normal or what.. my first time overclocking. Thanks Last edited by Lukepker; 01-08-2009 at 06:25 PM.. |
| Vista x64 + Windows 7 x64 (Ultimate) | Re: CPU issue Your noise could be just that the fan is now going faster than before, hence, making more noise than before, or is this a noise that has nothing to do with fans running at higher rpm? |
| Vista Ultimate 32 | Re: CPU issue |
| Vista Ultimate x64 SP1 | Re: CPU issue Take the side panel off the case, recreate the sound, try and isolate where it's coming from. |
| Re:IE8 Attachment Issue (was MSN Explorer/IE8 Attachment Issue) - update | Vista mail | |||
| Re:IE8 Attachment Issue (was MSN Explorer/IE8 Attachment Issue) - update | Live Mail | |||
| Windows Vista mouse issue.. Possibly ease of use type issue? | Vista hardware & devices | |||
| Monitor issue or full instal issue | Vista installation & setup | |||
| Routre Issue or Vista Issue | Vista General | |||
