Vista - Dell 530 OC help
Old 01-30-2009   #1 (permalink)
Vista Home premium 32bit, SP2
Dell 530 OC help
I have a stock dell 530 with q6600 CPU and a 0FM586 MoBo, should I OC and will it be safe with stock cooling? I went into the bios (phoenix 1.0.16) and there is no MIT setting.
Old 01-31-2009   #2 (permalink)
ultimate 64 SP1
Re: Dell 530 OC help
Quote  Quote: Originally Posted by venom762 View Post
Hi venom762 ...welcome to the x64 forums
you cant OC a dell my friend, the BIOS is locked down to prevent tampering.....
the ONLY way possible to OC it would be through windows via a few dedicated apps..... I DO NOT RECOMMEND THIS!!
the problem you'll have is even though we may find you an app capable of upping your FSB, the board itself has no voltage control, so it will become unstable very quickly...
TBH if you wanna OC, grab a new 775 mobo, remove your Q6600 & replace with a cheapo C2D & build a dedicated OCing rig....
SK
Old 01-31-2009   #3 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
yep, grab a new mobo if you want to OC.
Overclocking is not reccomeded with stock coolong either mate.
Old 01-31-2009   #4 (permalink)
Thank you it looks like a good forum, and I did not know this thank you for the help.
Old 01-31-2009   #5 (permalink)
No problems
Old 01-31-2009   #6 (permalink)
Windows 7 RTM 64-bit
Inspiron 530 is a failure . . . Dont even try to mess up with this computer. It will give you nothing but problems. Its outtta my experience as i work for Dell. Let the computer run as it is! Mark my words...
Old 03-22-2009   #7 (permalink)
vista ult
Hi venom. The dell 530 with the q6600 is a great overclocker, sorry you guys are unfamiliar with it.
There's a totally easy tape method similar to the old amd 'tape over the pin' method.
Here's a good tutorial with pics. enjoy
Dell Inspiron 530 Core2Quad q6600 minitower cheap overclocking - success!
Old 03-22-2009   #8 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by Cartier View Post
if your talking about a BSEL MOD, its a lot of fiddling around for a pretty small FSB jump....IMO
though i'd certainly prefer ppl used this method than using OC S/W to change BIOS settings, this method ALWAYS ends in disaster....
SK
Old 03-22-2009   #9 (permalink)
Vista Ultimate x64
Thats the one...
Ups the fsb to 1333 from 1066...
Personally....
I wouldnt. But apparently its safe.
Dell/Google Home Page: Acting Strangely In Dell XPS-420 Vista General
Dell AIO 948 Vista print fax & scan
Got My Older Dell 8400 Repaired By Using Parts From My Broken Dell XPS 600 And Installed RC1! Vista General
Dell Inspiron 9400 - Dell 1390 wireless card Vista hardware & devices
