Vista - EVGA GPU voltage tuner
Old 02-13-2009   #1 (permalink)
ultimate 64 SP1
Quote:
Exclusive EVGA GPU Voltage Tuner v.1.0
EVGA now gives you even more ways to maximize your EVGA card, with the exclusive EVGA GPU Voltage Tuner (GVT). This utility allows you to set a custom voltage level for your GTX 295, 280 or 260 graphics card. (see below for full supported list) Using this utility may allow you to increase your clockspeeds beyond what was capable before, and when coupled with the EVGA Precision Overclocking Utility, it is now easier than ever to get the most from your card. With these features and more it is clear why EVGA is the performance leader!
Features:
* Provides an environment to possibly increase your GPU voltage allowing for higher Core/Shader clockspeeds.
* Easy to use interface, with “Apply at Startup” functionality so you do not need to apply on every bootup.
System Requirements:
* Windows XP, Vista and 7. (Both 32/64bit)
* Supported EVGA graphics card (see below)
* Forceware 181.22 or higher drivers
source
its only able to alter EVGA cards currently, but there will be mods on the way allowing other GT200 vendors to use this S/W..
SK
General RAM voltage question General Discussion
Increase GPU Voltage? Graphic cards
How do i change the voltage to DDR Overclocking & Cooling
How do i change voltage to the DDR? Overclocking & Cooling
clock over-charging voltage Overclocking & Cooling
