| Vista 64 Bit | Temps Before and After Just wanted to post the difference between my two different cases I used to have a CoolerMaster and now have as you know an Antec 1200 Here is the difference in temps I also do not overclock Last edited by Jekyll and Hyde; 02-13-2009 at 07:55 PM.. Reason: Added info |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Temps Before and After hmm not much difference but you do have a sweet case |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Temps Before and After I'd say 6c cooler just by being in a new case is pretty good actually |
| Vista 64 Bit | Re: Temps Before and After Oh thanks!! there was I thinking that you were going to say WoW lol (no offence) But yes its a great case, quiet too, much quieter than the CM Cheers Smarteyeball |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Temps Before and After It's good that it also passes the quiet test for you JH. I'd also bet that all your other temps (HDD, mobo etc) will be cooler as well |
| | #6 (permalink) |
| Vista 64 Bit | Re: Temps Before and After Thanks mate, How would I fnd that out though? I do have another program CoreTemp would that be the one? Chris |
| | #7 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Temps Before and After coretemp or relatemp for the CPU temps (although the case shouldn't affect them too much) I mainly use Everest to monitor a lot of things: Lavalys - Comprehensive IT Security and Management The temps are found under computer>sensor Last edited by smarteyeball; 02-13-2009 at 11:35 PM.. |
| | #8 (permalink) |
| Vista Ultimate x64 | Re: Temps Before and After thats a great increase for only changing a case, but thats what good Cable management and great airflow will do for you, now replace all those fans with better ones. haha. What CM case did you have before your 1200? |
| | #9 (permalink) |
| Vista 64 Bit | Re: Temps Before and After Sorry for the late reply, not been well Unfortunately as hard as I have tried I cannot find the CoolerMaster case I had, I went to their website, but its not listed there so sadly can't show you I can definately see a massive difference when I look through the see-thru window, so much room , nice big spaces, not all cluttered up with cables etc....... Thanks Smarteyeball, I'll check that program out ![]() Chris |
| What are your Lowest Cooling Temps? | Overclocking & Cooling | |||
| Core Temps and stuff | Overclocking & Cooling | |||
| Are these temps right? | Overclocking & Cooling | |||
| cpu and core temps | Overclocking & Cooling | |||
| CPU cooler/temps? | Vista hardware & devices | |||
