Vista Tutorial - Q6600 temp, is this normal?
Old 03-01-2009   #1 (permalink)
Vista Home Premium 32bit
Hello,
Below is a screen shot of my speedfan test result, is this considered to be high?
Click the image to open in full size.
Is this normal?
Old 03-01-2009   #2 (permalink)
PC Geek
Vista Home Premium x64
Re: Q6600 temp, is this normal?
Quote  Quote: Originally Posted by TheRekz View Post
Hello,
Is this normal?
its normal if you have bad airflow or a dusty heatsink
Old 03-01-2009   #3 (permalink)
so 40 is the normal temp? what's the upper limit?
Old 03-01-2009   #4 (permalink)
PC Geek
40 is my temp with good airflow and an overclocked processor, if yours is stock at that temp then you need to clean/change your cpu fan.
Old 03-01-2009   #5 (permalink)
The Contemplator
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
There are two versions of the Q6600 processor. Use CPUID from http://www.cpuid.com/download/cpuz_150.zip to determine the correct one.
Old 03-01-2009   #6 (permalink)
I have the SLACR and yes it's overclocked otherwise I won't be posting it here. It seems weird as when i try to increase the fan speed from speed fan, nothing seems to change... why is this?
Old 03-02-2009   #7 (permalink)
Geek
Vista Ultimate 64bit
Dwarf i don't see that info screen from the link you posted on my machine ? ?
Old 03-03-2009   #8 (permalink)
The Contemplator
@patio - I didn't actually post a link to the information from Intel. Instead, I went to the page and snipped the relevant information and attached it to my post. The link I provided was to a program which can reveal the type and build revision of the processor in your system so that you can compare it.
For the sake of completeness, here are the links from Intel:
SLACR Intel® Core™2 Quad Processor Q6600 - SLACR
SL9UM Intel® Core™2 Quad Processor Q6600 - SL9UM
Old 03-15-2009   #9 (permalink)
I Tunes hates Me
Vista Home Premium 64bit SP2
You manually set your voltages when you overclocked yes? you didnt leave it on automatic did you? What voltage and clock are you running? and have you disabled intel speed step and / or C1E? (all this can seriously affect your idle temps)
That said dont worry too much about your idle temps (unless of course they are ridiculously high ) , its your full load temps you need to worry about.
Get yourself the latest version of Real temp Real Temp - CPU temperature monitoring and some software that will push your CPU , Id recommend Prime 95 or if your feeling daring Intel burn test Stability / Burn-in - EXTREME Overclocking
Run real temp alongside Prime 95 for a good hour , take note of your max temps on all four cores and report back here with them
Q6600 @ 2.4Ghz right.... General Discussion
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
Ga-x38-ds4+q6600+? Overclocking & Cooling
Normal temp of a GPU? Graphic cards
Media Player raises CPU Temp-Is this normal? Vista music pictures video
