| Vista Home Basic 32 bit | I7 920 overclock I recently overclocked my cpu from the stock 2.67 to 3.8 Bclk 194 cpu volt 1.4 Dram bus volt 1.50 Qpi/dram core volt 1.375 Temperature was fine Which ran fine gave it a few tests (prime95) which was all good, but there was a problem with the sleep function if i did it a second time vista would not boot, i would just get a black screen, and twice when i turned the computer on it gave me a overclock failed message, if i restarted it all was good but i was unsure so now im running it stock. My first question in what went wrong, secondly i have been getting a few errors with various programs (java, call of duty 5, crysis) they have been crashing from time to time, the solution centre found a problem and gave me this message "This problem was caused by a compatibility issue between this version of Windows and a chipset in your computer. The chipset was created by Intel Corporation. The model name of the chipset that caused this problem is The link was to an older driver than the one that came pre-installed and a few people that have also had this problem said the old driver did not fix the problem, or did not support the motherboard (thats what i got even though i have the same board, ASUSTeK Computer Inc.-Forum- P6T - Which Intel INF driver to use?) Anyone have any ideas?? Specs: Intel i7 920, Asus P6t motherboard, Gigabyte 9500gt 1gb, Seagate es2 barrcuda, 2gb ddr3 ram (jetram, transmedia), trition 81 cpu fan + 4 case fans thanks |
| Vista Ultimate x64 | Re: I7 920 overclock I am having the same problem...same error message. Wondering if the sleep state is making the voltage too low, so when it tries to wake up the system fails. |
| Vista Home Premium 64bit SP2 | Re: I7 920 overclock have you disabled C1E and EIST? |
| Vista Ultimate x64 | Re: I7 920 overclock Archie...sorry to noob out, but I have no idea what those abbreviations stand for. Please explain. |
| Vista Home Premium x64 | Re: I7 920 overclock C1E - Enhanced Halt State "Whenever the OS executes the halt instruction, the CPU enters what is known as the halt state. Architecturally, what's going on in a halt state is the clock signal is shut off to the CPU for some period of time. With no clock signal, none of the logic in the chip will do anything and thus power consumption is reduced. Performance is also significantly reduced; however, the halt instruction isn't usually called during application usage, so the performance aspects of the halt state aren't very important.EIST: "What EIST does is very similar to AMD's Cool'n'Quiet. It is demand based reduction in CPU clock speed and voltage. Using the same mechanism of adjusting clock speed and voltage, based on the application demand, the processor will dynamically increase/decrease its clock speed between its minimum clock and its normal operating frequency, as well as voltage, in order to optimize for power consumption. |
| | #6 (permalink) |
| Vista Home Premium 64bit SP2 | Re: I7 920 overclock what he said ^^^^^ ![]() im wondering if your bluescreens on wakeup are due to low voltage to the cpu , normally not a problem unless its overclocked if your overclocking its generally a good idea to turn these options off in your bios they can play havoc with your oc |
| | #7 (permalink) |
| Vista Ultimate x64 | Re: I7 920 overclock So how exactly do you enact, or turn off, the above power states? Also...I would definitely trade an OC that ran a little cooler but that did not use the reduced power modes (that drop cpu multiplier) if it meant more stability and no wonkiness on wake up. I may give that a try also. I;m running a 940 @ 3.52 ghz (x160) with 1.2v to cpu, 1.25 to QPI, and 1.64 on Ram. Using ASUS P6T6 WS Revolution board in SLI. |
| | #8 (permalink) |
| Vista Home Premium 64bit SP2 | Re: I7 920 overclock its just a suggestion mate it may not work , but its worth a shot , its a good idea to turn them off anyway if your overclocking , you'll find the settings in your bios , you'll have to look them up in your mobo book or just have a poke around your bios its not hard to find ![]() Another thing with an overclocked rig if your not bothered about the noise its also a good idea to run your cpu cooler at full speed , disable its auto setting again in bios , this keeps your idle temps down , its up to you |
| can overclock gpu | Overclocking & Cooling | |||
| To Overclock or Not Overclock? | Overclocking & Cooling | |||
| Ati Overclock | Graphic cards | |||
| Should I Overclock? | Overclocking & Cooling | |||
| Overclock 101 | Overclocking & Cooling | |||
