Vista Tutorial - Help needed: CPU getting extremely hot even on Idle
Old 04-17-2009   #1 (permalink)
Newbie
Vista Home Premium SP1, 32bit
I have recently purchased HP Pavilion tx2500 Entertainment Notebook PC and I am currently running Windows Vista Home Premium SP1. The notebook was preloaded with this OS.
My configuration is:
AMD Turion X2 Dual Core RM-70
3MB RAM
ATI Raedon HD 3200 graphics.
My problem is that right from the very first day my notebook is getting extremely hot. I checked the CPU temperature with Speedfan. It shows on an avg 75C even when nothing except the kernel is running.
More alarming is the CPU usage. Even when nothing is running and the machine is idle, explorer.exe in the task manager shows 40-50% CPU usage.
I disabled aero as well as windows search but to no avail. Please advice me if anybody has any idea regarding this.
Old 04-17-2009   #2 (permalink)
Vista Ultimate x64
Re: Help needed: CPU getting extremely hot even on Idle
Disabling Aero wont help. Go HERE and go to the last two replies on that page and do as they suggest to see if it helps.
Old 04-17-2009   #3 (permalink)
Newbie
Quote  Quote: Originally Posted by stew2 View Post
Thanks for the help. Actually it didn't work.
My problem is a bit different from them. Their CPU usage shoots up after opening the windows explorer, however my CPU usage is high right from the start and it never comes down. Best case is around 45% usage. This is unbearable. My idle temps are reaching late 70s.
Old 04-17-2009   #4 (permalink)
Vista Ultimate x64
OK well get the basics out of the way first. What Virus Scanner are you using?
Old 04-17-2009   #5 (permalink)
I Tunes hates Me
Vista Home Premium 64bit SP2
hold down ctrl and alt hit delete once , under the processes tab what servce is taking up your cpu cycles
Old 04-17-2009   #6 (permalink)
Pew Pew lazor beemz
Vista Ultimate x64
If this is a new notebook, I would only do some checking to see what is actually causing the cpu workload and see if there is something you can disable to calm it down somewhat...
Other than that, I would honestly be returning it and getting a new one.
Old 04-18-2009   #7 (permalink)
Newbie
I am using avast home version.
Quote  Quote: Originally Posted by archie123 View Post
explorer.exe is taking the maximum cpu cycles, its cpu utilization is around late 40s even when idle.
Quote  Quote: Originally Posted by moirae View Post
Can you really do that? I am unaware of such a policy please enlighten me.
Ans Thanks everybody for your help.
Old 04-18-2009   #8 (permalink)
Older But No Wiser
Vista Ultimate SP2/Windows 7 Ultimate x64
There was a warning published a while back regarding HP notebook batteries overheating. Is yours one of those perhaps?
PC Notebook Computer Batteries Recalled Due to Fire and Burn Hazards
The other reason could be spyware. Check for infection using the free versions of both of these tools and let them clean everything they find:
http://www.superantispyware.com/supe...freevspro.html
http://www.malwarebytes.org/mbam.php
Old 04-18-2009   #9 (permalink)
Vista Ultimate x64
OK download ESET and do a full scan and remove any viruses. If the scan came up clean then click the link in my sig and do as it says then reboot your laptop and see if the problem is still there.
If the problem still exists then reboot and tap F8 and select Safe Mode and let us know if the problem exists in safe mode.
Old 04-18-2009   #10 (permalink)
Vista Home Premium 32bit and Kubuntu 9.10
It might be because you have an AMD processer. I have a cousin and we have almost identical specs except he has less ram and he has an amd. He has CQ60 like me and his computer also gets really hot even on idle
Extremely Annoying Live Messenger
Vista extremely long shutdown and startup troubleshooting needed! Vista General
Vista extremely long shutdown and startup troubleshooting needed! Vista performance & maintenance
CDR running extremely slow... Vista hardware & devices
Installation is extremely laggy Vista installation & setup
