Vista Tutorial - Are these temps right?
Old 05-14-2009   #1 (permalink)
Microsoft Vista Ultimate x64
Are these temps right you think? I am stock speeds with a Xigmatek Dark Knight at half speed....
What is VREG? that seems hot, but CPU seems a little cool to me.
Old 05-15-2009   #2 (permalink)
ATI\AMD <3 Jesus..<3
Vista Home Premium 32bit and Ubuntu 9.10 32bit
Re: Are these temps right?
hm... it prolly is correct.......... go to http://www.cpuid.com/ and get the hardware temp monitor
Old 05-31-2009   #3 (permalink)
Vista Home Basic 32 bit
Quote  Quote: Originally Posted by Butler View Post
Attachment 12869
Quote:
VREG temperatures are the temperature of the CPU voltage regulators. Basically it's the system of voltage regulators, the power suppply to the processor. 65C is not too high of a temperature. Most of the parts in the vregs are rated for 105C, for instance the caps. That does not mean that 105C is safe but, the system can handle that if needed. At temperatures above 80C it might start to impact the health and impact the performance of your motherboard.
Googled it Butler , hope that helps you .
Old 05-31-2009   #4 (permalink)
Master
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Old 06-01-2009   #5 (permalink)
im coming for cake
ultimate 64 SP1
temps seem fine mate.......
SK
Old 06-01-2009   #6 (permalink)
I Tunes hates Me
Vista Home Premium 64bit SP2
yeah there ok , if it bothers you disable fan speed control in yuor bios , if you can stand the noise
of topic........
******** deleted i was rambling
What are your Lowest Cooling Temps? Overclocking & Cooling
Core Temps and stuff Overclocking & Cooling
Temps Before and After Overclocking & Cooling
cpu and core temps Overclocking & Cooling
CPU cooler/temps? Vista hardware & devices
