| Member | Can a PSU cause heat problems? I have been having alot of problems with a stock gateway lx 6810-01 Problem is the cores are running at like 60c and I know thats above normal. My question is, can a stock PSU have anything to do with the cores running too hot? |
| Lost in my own World | Re: Can a PSU cause heat problems? only if the cpu fan is not getting enough power from the psu. |
| Member | Re: Can a PSU cause heat problems? What would be considered the CPU fan? We bought a new heat sink thats huge and says it runs around 2200 rpm's at max with a little knob you turn, but it runs at 900 rpm's at max. So, PSU issue? Or heat sink issue? Thermaltake - 120mm CPU Cooling Fan - CL-P0401 As you can see, the fan is built into the heat sink. The only other fans I see in the computer are 1 on the GPU and 1 on the PSU. |
| Lost in Cyberspace | Re: Can a PSU cause heat problems? The only thing I can think off is that the PSU is super cheesy and not capable of handling the mobo + other hardware and it is suffocating itself. That or your case is not well ventilated and/or you need to add a couple of fans for more airflow Third, you can get into the BIOS and manually adjust your fans to 100% so they are blowing at max all the time, it will get noisier but it will cool down your temps. Last thing I can say is perhaps you used to much, to little or no compound at all when you installed the heatsink. |
| Member | Re: Can a PSU cause heat problems? And how would one go about manually changing all of my fan speeds? I'm looking in bios on that gateway and I see no such option.. The only relative options are Smart fan with an option to enable or disable and quiet startup. I don't see anything else fan related. |
| | #6 (permalink) |
| Lost in my own World | Re: Can a PSU cause heat problems? what is the model / power rating on your psu. also download a program called speedfan and you can really see what the rpms are at |
| | #7 (permalink) |
| Lost in Cyberspace | Re: Can a PSU cause heat problems? OK, is "Smart Fan" disabled or enabled? If I am not wrong... Enable = The Bios will dictate how much % speed to let the fan run according to heat temps. Disable = No matter what, the fans will run at 100%... This is what you want! |
| | #8 (permalink) |
| I Tunes hates Me | Re: Can a PSU cause heat problems? did you fit the heatsink / fan correctly? what paste did you use? how much did you use? have you tried removing it , cleaning and reseating? |
| | #9 (permalink) |
| Member | Re: Can a PSU cause heat problems? fadedrs: We have speed fan already, both the bios and speedfan report the low 900 rpm's. It's a LiteON ps-6401-3 psu at 500w. AstaLaVista: It was enabled, I disabled it yesterday only to find that the RPM's all ran the same. Archie123: Yes we mounted it correctly with both the stock one, and the new one. We used this exact brand of Thermal Compound. Dynex® - Silver Thermal Compound - DX-STC 100 At first we applied too much after watching a ton of vidoes about proper application of thermal compund.. After wards we put a little bead in the the center and set the heat sink on it again and let it spread. (We used 99% isopropyl alcohol to clean after each application) I believe too much is bad and too little is bad so we just did the "blob technique" according to a few videos. (Just read a review on this paste, apparently according to one person it takes about 3 days to reach maximum heat transfer) |
| | #10 (permalink) |
| Lost in my own World | Re: Can a PSU cause heat problems? maybe return it sounds like the fan is defective this is the one i have Micro Center - CNPS7500-AlCu LED Universal CPU Cooler never have an issue even after hours of straight game play. see attached pic. that is after 5 hours of straight game play. |
| Heat issues with amd!! | Vista performance & maintenance | |||
| A heat problem or CPU | Vista General | |||
| Heat | Vista hardware & devices | |||
| Testing System Heat (GPU & HD) | Vista hardware & devices | |||
