Vista Tutorial - Post your over-clocking results
Old 06-30-2009   #1 (permalink)
Vista Ultimate 32bit
Hello Guys,
Post your over-clocking results if you have over-clocked your CPU with the model of it.
I got my Intel Core 2 duo E8400 3.00Ghz to 3.85Ghz at stock cooling!
(I cant Believe it too.)
Old 06-30-2009   #2 (permalink)
Lost in my own World
Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86
Re: Post your over-clocking results
Quote  Quote: Originally Posted by amigo max View Post
Hello Guys,
yeah but can you run games and programs STABLE!
got my cpu from 2.6 to 3.3 ran vista fine, started up a game and it kept dumping, turned it down to 3.25 and it is fine.
Old 06-30-2009   #3 (permalink)
Vista Ultimate x64
Theres already a thread for this. Its HERE
But anyway i run my e6600 at 3.6Ghz thats a 50% overclock on the stock 2.4Ghz and run my FSB at 450 which is a 69% overclock. All stable and use the pc everyday including gaming etc...
Old 06-30-2009   #4 (permalink)
Quote  Quote: Originally Posted by fadedrs View Post
Hello Guys,
Yea its stable, pretty good. i will try about 4GHZ next week and then above 4Ghz.
Old 06-30-2009   #5 (permalink)
Quote  Quote: Originally Posted by stew2 View Post
well i know there is another thread for it but its too crowded i cant actually make out the posts.
AND that's a good overclock , great going ... and BTW what cooling r u using?
Old 06-30-2009   #6 (permalink)
Vista Ultimate x64
Its custom built watercooling as my case is a micro atx case. It can fit the micro atx motherboard, 2 hard drives and 1 dvd drive and thats it. I put my pump for the watercooling where a second hard drive would go and it pretty packed and toasty in there. It wont even run with stock coolers lol.
Old 07-01-2009   #7 (permalink)
Eye know, eye know
Vista Ultimate SP2 x64 : Seven Ultimate x64
I believe you got it there, but I also believe it would be running HOT
Old 07-01-2009   #8 (permalink)
yeah on stock cooling she would be running very hot.
Old 07-02-2009   #9 (permalink)
No its not running hot as per my CPU ID software it shows 40-45 at idle and upto 65 at load (i don't know if it is true.)
Old 07-02-2009   #10 (permalink)
Vista Ultimate x64
Although i like HWmonitor, I think EVEREST gives more accurate readings. My CPU idles at 30C on both HWmonitor and Everest but the temps for each core are different with Everest giving more believable results.
Post Your Overclock Results. Overclocking & Cooling
I'm new to under clocking- Plz Help. Overclocking & Cooling
over clocking a video card Graphic cards
Finally Got It To Show In Windows Update-Still Clocking Vista installation & setup
Over-Clocking in Vista 64 Vista General
