| Vista Home Premium x64 | CPU Cooler I am not overclocking my i7 but was wondering if anyone knows the best cooler that will fit with a gigabyte EX58UD4P with an i7 and in a Antec 900 case. I have two 3870X2's crossfired and the extra fan on the case side. I am running Rivatuner as the fan control on the ATI cat does not work for the 3870's. It never gets hot but I thought I might want to push it some and see what I can do. Yes, It has the stock Fan for the i7. LOL |
| Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86 | Re: CPU Cooler here are some universal coolers Micro Center - Extreme Spirit II Universal Northbridge Chipset Copper Heatpipe Cooler Micro Center - G Power Lite Universal Heat Sink Micro Center - 92mm 3-Heat Pipe Universal CPU Cooler Micro Center - CNPS7500-AlCu LED Universal CPU Cooler - i use this one overclocked and my temps never go above 38c there are two stores in cali or you can order online. |
| Vista Home Premium x64 | Re: CPU Cooler Thanks, I looked at them and they look nice. |
| Vista Ultimate x64, SP2 | Re: CPU Cooler Take a look at the Noctua NH-U12P, i cant fault this cooler, it also has a screw spring loaded base as opposed to those crappy push pins. |
| Vista Home Premium x64 | Re: CPU Cooler That baby looks sweet. It looks like it will fit nicely as well. Thanks. I will read up on it more. The price is right there were I want it to be as well. |
| | #6 (permalink) |
| Vista Ultimate x64, SP2 | Re: CPU Cooler Just one thing, it is a big cooler , so check it will fit, i have a coolermaster stacker 830 and i had to take out one of my side fans for this bad boy to fit lol. |
| | #7 (permalink) |
| Xp-Vista-7 | Re: CPU Cooler Hi Techymike don't want to barge in here but you ought to look at this as it's a bargain...and does the job quieter... Arctic Cooling |
| | #8 (permalink) |
| Vista Home Premium x64 | Re: CPU Cooler Noctua NH-C12P 120mm SSO CPU Cooler So far I have found this to be the best for my system requirements but I have not decided completely yet. I am in no rush as I don't overclock and the stock fan is doing just fine. I really appreciate all the help and inputs, this has been a tremendous assistance in my search. Thermaltake ISGC-400 CPU Cooler I added this as it has a good (not the best) cooling at a low profile fit design. After reading about it, the reviews all said that it fits great in a mid tower that has side fans. Thank you! Last edited by Techymike; 07-14-2009 at 11:31 PM.. Reason: added a cooler |
| | #9 (permalink) |
| Vista Home Premium x64 | Re: CPU Cooler The cooler came in fine. I installed it after looking at the paper directions and deciding the only use full thing was the air flow direction and picture of the cooler. Other then that it made a nice place mat for the work. Turns out there are 4 ways you can mount this and only one of them is correct. As long as you look at the airflow then you will have no problems. It took me about an hour to rip at all down and figure out the direction then clean out the dust bunnies. And have it all back working again. It fit reeeeeeeeeeeeeeeeeeeeeeeeally close to the side fan but there is not problem with the fit. The temps dropped to 40-43C from 53-57C. It was worth the time and money! Besides that it looks pretty cool as well. |
| | #10 (permalink) |
| Vista Ultimate x64, SP2 | Re: CPU Cooler Glad you got it fitted all ok, the drop in temps is quite impressive, you must be very pleased, good job. |
| Best cooler for Phenom II | Overclocking & Cooling | |||
| Best Cooler for Core i7 | Overclocking & Cooling | |||
| cpu cooler | Overclocking & Cooling | |||
| Thermal Electric CPU Cooler | Overclocking & Cooling | |||
| CPU cooler/temps? | Vista hardware & devices | |||
