| Vista Home Basic 32bit Service Pack 2 | Core Temps and stuff CPUID Hardware Monitor 1.1.4.0 ----------------------------------------------------- Mainboard Vendor Intel Corporation Mainboard Model D102GGC2 (0x1DA - 0x946EAA) LPCIO ----------------------------------------------------- Vendor SMSC Model DME1737 Vendor ID 0x55 Chip ID 0x78 Config Mode I/O address 0x2E Dump config mode register space, LDN = 0xA 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 78 03 08 00 44 00 2E 00 00 00 00 00 00 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 06 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Hardware monitor ----------------------------------------------------- SMSC DME1737 hardware monitor Voltage sensor 1 1.18 Volts [0x64] (CPU VCORE) Voltage sensor 2 3.32 Volts [0xC1] (ATX +3.3V) Voltage sensor 3 5.16 Volts [0xC6] (ATX +5V) Voltage sensor 4 11.86 Volts [0xBD] (ATX +12V) Temperature sensor 0 52°C (125°F) [0x34] (Diode 1) Temperature sensor 1 51°C (123°F) [0x33] (Internal) Temperature sensor 2 57°C (134°F) [0x39] (Diode 2) Fan sensor 0 1792 RPM [0xBC5] (FANIN0) Fan sensor 1 1450 RPM [0xE8D] (FANIN1) Dump hardware monitor SMBus Register space, base address = 0x03010 SMBus request at channel 0x0, address 0x2E 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 63 C1 C6 BD 34 33 3A 7A 0C 04 0F FF FF FF FF 30 76 76 76 00 00 00 00 00 00 00 00 00 00 00 5C 8A 40 05 01 00 00 00 FF 00 FF 00 FF 00 FF 00 FF 81 7F 50 81 7F 81 7F FF FF FF FF FF FF FF FF 42 42 42 CB 60 CB CB ED DD 61 61 61 35 35 35 45 45 45 44 40 00 70 79 79 79 09 09 09 09 09 09 00 00 00 40 00 EC 18 80 7E A4 0E 00 00 C5 92 10 D5 00 4D 4D 0B 0B 0E 00 90 04 04 04 04 0C 0C 0C 5A F1 C5 00 00 FF 00 FF 00 A0 00 00 0C 00 02 FF FF 0B 0B FE FF FE FF FF FF FF B0 FF 00 00 00 00 00 28 28 0E 0E 0F 0F 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Hardware monitor ----------------------------------------------------- GeForce 9400 GT hardware monitor Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core) Dump hardware monitor Hardware monitor ----------------------------------------------------- ST3160212A hardware monitor Temperature sensor 0 40°C (103°F) [0x28] (HDD) Dump hardware monitor Processors Map ------------------------------------------------------------------------------------ Number of processors 1 Number of threads 2 Processor 0 -- Core 0 -- Thread 0 -- Thread 1 Processors Information ------------------------------------------------------------------------------------ Processor 1 (ID = 0) Number of cores 1 (max 1) Number of threads 2 (max 2) Name Intel Pentium 4 631 Codename Cedar Mill Specification Intel(R) Pentium(R) 4 CPU 3.00GHz Package Socket 775 LGA (platform ID = 2h) CPUID F.6.5 Extended CPUID F.6 Core Stepping D0 Technology 65 nm Core Speed 2400.1 MHz (12.0 x 200.0 MHz) Rated Bus speed 800.0 MHz Stock frequency 3000 MHz Instructions sets MMX, SSE, SSE2, SSE3, EM64T L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size Trace cache 12 Kuops, 8-way set associative L2 cache 2048 KBytes, 8-way set associative, 64-byte line size FID/VID Control yes FID range 14.0x - 15.0x VID range 1.116 V - 1.324 V Features XD Thread dumps ------------------------------------------------------------------------------------ CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 01001003h Max CPUID level 00000006h Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x00000006 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x00000F65 0x00020800 0x0000E59D 0xBFEBFBFF 0x00000002 0x605B5001 0x00000000 0x00000000 0x007D7040 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00004121 0x01C0003F 0x0000001F 0x00000000 0x00000004 0x00004143 0x01C0103F 0x000007FF 0x00000000 0x00000005 0x00000040 0x00000040 0x00000000 0x00000000 0x00000006 0x00000000 0x00000000 0x00000000 0x00000000 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020 0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75 0x80000004 0x20342029 0x20555043 0x30302E33 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x08006040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 16 KB 2 thread(s) Cache descriptor Level 2 U 2 MB 2 thread(s) Cache descriptor Level 1 T 12 KB 2 thread(s) MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900 MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000 MSR 0x0000002C edx = 0x00000000 eax = 0x0C12030F MSR 0x000001A0 edx = 0x00000000 eax = 0x22252089 MSR 0x000001A1 edx = 0x00000000 eax = 0x00000000 MSR 0x00000198 edx = 0x00000F27 eax = 0x00000F27 MSR 0x00000199 edx = 0x00000000 eax = 0x00000F27 CPU Thread 1 APIC ID 1 Topology Processor ID 0, Core ID 0, Thread ID 1 Type 01001003h Max CPUID level 00000006h Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x00000006 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x00000F65 0x01020800 0x0000E59D 0xBFEBFBFF 0x00000002 0x605B5001 0x00000000 0x00000000 0x007D7040 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x00004121 0x01C0003F 0x0000001F 0x00000000 0x00000004 0x00004143 0x01C0103F 0x000007FF 0x00000000 0x00000005 0x00000040 0x00000040 0x00000000 0x00000000 0x00000006 0x00000000 0x00000000 0x00000000 0x00000000 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020 0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75 0x80000004 0x20342029 0x20555043 0x30302E33 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x08006040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 16 KB 2 thread(s) Cache descriptor Level 2 U 2 MB 2 thread(s) Cache descriptor Level 1 T 12 KB 2 thread(s) MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800 MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000 MSR 0x0000002C edx = 0x00000000 eax = 0x0C12030F MSR 0x000001A0 edx = 0x00000000 eax = 0x22252089 MSR 0x000001A1 edx = 0x00000000 eax = 0x00000000 MSR 0x00000198 edx = 0x00000F27 eax = 0x00000F27 MSR 0x00000199 edx = 0x00000000 eax = 0x00000F27 Drive ----------------------------------------------------- Name ST3160212A Drive ----------------------------------------------------- Name WDC WD800BB-32BSA0 Drive ----------------------------------------------------- Name Generic USB CF Reader Drive ----------------------------------------------------- Name Generic USB MS Reader Drive ----------------------------------------------------- Name Generic USB SD Reader Drive ----------------------------------------------------- Name Generic USB SM Reader Display API(s) ------------------------------------------------------------------------------ NVIDIA direct I/O API NVAPI display API Display Adapter(s) ------------------------------------------------------------------------------ Device number 0 Name GeForce 9400 GT Vendor ID 0x10DE (0x3842) Model ID 0x641 (0xC945) Revision ID 0xA1 Perf Level 3D Applications GPU core clock 550.0 MHz GPU shaders clock 1375.0 MHz GPU memory clock 400.0 MHz GPU temperature 45 C Any advice to help me lower all these temps? And not something like "Install another fan dumbass!" Would you advice running open case, or what would be a quick, inexpensive fix for this problem, temporarily at least? |
| Vista Home Premium 64bit SP2 | Re: Core Temps and stuff your gpu is fine your cpu seems high download and install this Real Temp - CPU temperature monitoring let me know what thats reporting |
| Vista Home Basic 32bit Service Pack 2 | Re: Core Temps and stuff It says that my processor isn't supported o.o |
| Vista Home Premium x64 SP2 | Re: Core Temps and stuff wow. still stickin with the 'ol, but interesting hyperthreaded pentium 4 huh? i always like it when i find someone still using it because it was intel's first attempt at a ht processor. i wonder, does it run close to a dual core? |
| Vista Home Basic 32bit Service Pack 2 | Re: Core Temps and stuff I think it Is duel core. I know it has one physical processor and two logical processors. |
| | #6 (permalink) |
| Vista Home Premium x64 SP2 | Re: Core Temps and stuff ). |
| cpu and core temps | Overclocking & Cooling | |||
| Vista freezes solid on AMD dual core, single core ok | Vista hardware & devices | |||
| Dual core cpu problem, only one core being found by Vista Ultimate 64 bit | Vista installation & setup | |||
| Intel duel core question with Vista 2nd core not showing being used Help? | Vista General | |||
| Which version support dual core or quad core? | Vista General | |||
