Vista - Temp overshoot!
Old 08-13-2009   #1 (permalink)
Vista Home Premium 32bit
Temp overshoot!
Hey guys, i just add another 2GB ram in my laptop. here's what happen:
Before adding 2GB: temp around 62-66 Degrees.
After adding 2GB: temp around 68-74!! Degrees.
i've tried removing the 2GB from my laptop just to check if it is the ram that causing the temp to increase. and yes. after i removed. it drops down to normal temp.
What's actually going on? and how do i resolve this?
Old 08-13-2009   #2 (permalink)
Vista Ultimate x64, SP2
Re: Temp overshoot!
Hello Sicknerd,
It could just the extra heat generated by the two new sticks, or they may of altered the airflow in the laptop.
Thats all i can think of, i suppose, because the system is working faster, it could generate more heat because of that.
Hope this gives you a clue, good luck and let us know how it goes.
CPU Temp General Discussion
Is my core temp too hot? Overclocking & Cooling
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
PC Temp Overclocking & Cooling
temp Vista mail
