| Vista Home Premium x64 | Talk about hot... I was using the Dv7 doing 3D modeling with 2 models at the same time on my screen. I checked the temps at the time....87 Degrees Celegrade!!! I was like no way this is happening. I am assuming that this is bad...but does anyone have any suggestions on how to possibly cool this down or is it acceptable at times to have this happen when I am modeling? I need to get some canned air to clean it out some so that may make a difference. Thanks in advance. |
| Vista home premium 32bit | A chillpad like one of these helps: BestBuy.com - Search Results - 87C is not healthy. Last edited by whs; 08-17-2009 at 03:13 PM.. Reason: typo |
| Vista Home Premium x64 | I have tried looking at stores and I am yet to find a cooler for a 17" laptop. They are usually the size for 14.1" laptops and mine is just way to big for one of those. |
| Vista home premium 32bit | Have a look at this report: Amazon.com: Suzanne "Suzanne"'s review of Targus PA248U Notebook Chill Pad |
| Vista Ultimate 64-bit, SP2 | Hi Blackhawk7188, I flog a similar HP laptop to yours. I have mine raised at the back to allow for better air circulation. Have you turned your laptop over to clear the grot away from the air intake area? |
| | #6 (permalink) |
| Vista Ultimate x64, SP2 | Hello Blackhawk7188, What did you use to measure the temperature ?. |
| | #7 (permalink) |
| Vista Home Premium x64 | I use Core Temp x64 Edition. And I just cleaned it out last night, now it just comes down to when I need to model next time. |
| | #8 (permalink) |
| Vista Ultimate x64, SP2 | Try SpeedFan and see if you get the same results. Download SpeedFan - Access temperature sensor in your computer Give it a go and post your results. |
| Wireless Vista laptop connection to Talk Talk | Network & Sharing | |||
| Can WLM talk to Mac iChat? | Live Messenger | |||
| can you talk with people on aim using WLM? | Live Messenger | |||
| Talk about WOW | Vista General | |||
