Vista - Overclock Help
Old 10-19-2009   #1 (permalink)
Vista Home Premium x64
Overclock Help
Hey. I could need some helpful tips in overclocking my Intel Core i7 950 3.07 GHz
I know there is a lot of guides and stuff about OC but some personal help would really be appreciated.
Check my specs for more info on my system.
I really want to make this overclocking the right way. I OC'd my last Core duo 3.16GHz a bit but it never felt safe.
So any tips or anything to get me started would be great
Old 10-20-2009   #2 (permalink)
Vista Ultimate x64, SP2
Re: Overclock Help
Hello hawkin90,
The first thing you need to do is to go in to your Bios and see how much of it is unlocked, Dell along with most manufactures lock there Bios's to stop overclocking, so take a look and see what you have available.
Old 10-20-2009   #3 (permalink)
Re: Overclock Help
Yeah just found out I can't overclock. Don't have access to edit anything important in Bios. I OC'd my grahpics card yesterday though..but still, a little irritating.
Old 10-21-2009   #4 (permalink)
Re: Overclock Help
Pity, thats the problem with manufacturer built machines, but it's a nice rig.
Old 10-23-2009   #5 (permalink)
Re: Overclock Help
Thanks Yeah I like it
I7 920 overclock Overclocking & Cooling
can overclock gpu Overclocking & Cooling
To Overclock or Not Overclock? Overclocking & Cooling
Should I Overclock? Overclocking & Cooling
Overclock 101 Overclocking & Cooling
