I am having a problem with my PC. It is a home built with a Gigabyte EP45T Extreme motherboard with a Intel 9550 CPU, 4 GB DDR3 Corsair ram, Gigabyte Nivida GT280 video card and 2 700GB Sata 2 drives set up in a RAID0 array.
I have tried overclocking and cannot get it stable. Runs fine for a time and then suddenly starts not to POST. I have gone back to completely standard to see if I can find the problem and even with that there are issues. The drive has two Primary partitions and one extended that is devided up into other partitions. The first primary holds Vista x64 and the second is going to hold Windows Server 2008 as a demo trial.
Symptoms. One symptom is that when it goes to power up the fans start up, it tries to POST and then shuts itself down and does that in a continuous loop. There is no beeps or any response at all. Looking at the lights on the MB all seems normal. To fix this I have to remove the video card and pop out the memory and put it all back in and then it works. Almost as though something has not seated properly.
Second symptom is that access to the drive appears very slow but a read test shows quite good compared to another PC that is slightly under powered from this one. Getting up around 220MB/sec read speeds.
Third symptom and has only just started since I tried to install Windows Server 2008. Got it installed but the version I had must have had a preinstalled key on it and it would not give me the trial so I reformated the partition and started again.
Now every time I go to install it, it will fail saying the file is corrupt. After cancelling and restarting the POST screen takes ages to scan through the SATA ports and one drive is usually missing (I am assuming this is the cause of the corrupt file as well). Other times the drives show up but the RAID array does not show up. Only way to fix it is to power the machine down (not simply reset) and power up again and it usually boots up fine.
Sorry for the long post but it is driving me batty. This is my 6th PC I have built and while I have had the odd trouble with the others they have been quickly traced down to faulty memory or a drive that failed. I am at a loss with this one.
The video card is huge and actually sits on the SATA connector for the DVD but it looks fully seated and is locked in with the clip.
The only other thing nearby is a Draytek 2820n router that has wireless. It is sitting fairly close to the PC and above it.
Any suggestions welcome.
- Homebuilt
- Intel Q9550
- Gigabyte GA-EP45T-EXTREME
- 2x2GB Cosair DDR3
- Graphics Card(s)
- Gigabyte GV-N28-1GH-B GTX 280, 1024MB
- Onboard
- HP LP2475w 24" LCD
- 1900x1200
- 2 x 750GB Segate SATAII as a RAID0
- PSU
- Enermax Galaxy, 1000W, Active PFC
- Case
- Zalman Z-Machine GT1000
- Cooling
- Air
- Standard
- Standard
- 1MB
