Max Temp on MSI ATI cards?
im currently running a MSI cyclone and trying to keep it under 70C can i OC it more and get it to 80 or more with out damageing it?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Saitek 2
    Logitec G9
    Major AMD, ATI and MSI Enthusiast.
also anyone know the perfect voltage tweak for the MSI 4890 Cyclone with out breaking it?
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
Try to keep the GPU core below 90c (they are rated up to 100-105c, but will shorten life at those temps).
80-85c ish is fine.
However it's the VREGS that you should also keep cool - 90c is hot, 95c is very toasty and 100c is thermal shut down territory.
As for voltage tweaks, there are several tools available.
MSI Afterburner
RBE
About 1.4v is the max 'safe' limit you should be looking at for air cooling. Lower is obviously better.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
hey smarty thanks for the reply i have found some of the programs but they say my card isnt supported
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
if you could do some reasearch on the MSI 4890 OC Cyclone and see if theres a way to tweak it that would be great iv tried plenty of times and came up with nothing
Currently what i have clocked is 900mhz core and memory speed 1.1x4ghz
original clock speed is 880mhz mem speed 975x4 ghz
<qtlbar id="qtlbar" dir="ltr" style="display: inline; text-align: left; line-height: 100%; padding: 0pt; background-color: rgb(236, 236, 236); -moz-border-radius: 3px 3px 3px 3px; cursor: move; z-index: 999; left: 8px; top: 106px; opacity: 0.9;">
<iframe id="qtlframe" src="" style="display: none; border: 1px solid rgb(236, 236, 236); background-color: white;"></iframe></qtlbar>
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
apparently the max voltage i want is 1.47 to get the clock to 1ghz but how to get that on the card any suggestions im been messing with RBE but idk how to set it up to that
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
