Problem:
I am a bit concerned that my Laptop CPU could be under pressure by running at temperatures that are too high, and consistently for too long.
Background:
1. See my system specs for system details.
2. Snips taken from screen-shots courtesy of Piriform Ltd - 'Speccy'
Because I don't believe in it and don't use air-conditioning, the laptop is constantly being used in room temperatures that can vary from 22° to 34° Celsius [72° to 93° Fahrenheit], and in humidity that can range from 75%, right through to 98%. I do have free and open space under the laptop, and a desktop fan is constantly directing a good blast of air at the laptop position.
Screen-snips from 'Speccy':
Laptop CPU temperatures when it is basically at idle look like this;
.....and with a couple of websites up and a bit of software running, the CPU temperatures looks like this;
Keeping the Laptop free from dust and dirt:
I'm aware that dust and dirt can play havoc with Laptop internal fan efficiency, and am constantly cleaning all the vents using a small hand-held battery-driven vacuum cleaner, and can't do much more than that.
Blasting the dust using cans of compressed air - for a Laptop; Yes or No:
Or can I use the cans???..... Are the compressed air cleaners in a can available at most computer and tech shops, of any use in cleaning Laptops? I am a bit wary of them, knowing that some have been known to introduce moisture into the units, during use as cleaners. Besides, I am none too keen in using something that could be blowing dust etc., further into the body of a Laptop. But are there any alternatives, other than removing the back and cleaning the fan that way??
Summary:
So, do my temperatures look anything out of the ordinary, and which is the best method in keeping the Laptop free from dust and dirt?
