CPU Fan
  1. #1
    Junior Member
    Vista Home Premium 32bit
    Local Time: 01:48 PM
    CPU Fan
    I have a AVC DS09225R12EPO58 12v-0.1A CPU fan of the sealed hydraulic bearing type, with a four pin mother-board plug. It is sandwiched between a cooper tube and fined type heat-sink, cooling a Pentium D 2.80Ghz. on a Medion PC with MSI Mother-board, This fan is so noisy and vibrates, there is no oil point under label. What, would be a good replacement fan to fit this heat-sink.
  2. #2
    Senior Member
    Ultimate x64, home Prem 64
    Local Time: 08:48 AM
    canada
    Re: CPU Fan
    Best/easiest is to just replace the unit.
    Any of these should be fine.. I think you are socket 775
    Newegg.com - Computer Hardware,Fans & Heatsinks,CPU Fans & Heatsinks,LGA 775
CPU Fan problems?
