Fan Speed
  1. #1
    ChaosDark's Avatar
    Vista x64 Home Premium SP2
    Local Time: 10:44 AM
    usa us massachusetts
    Fan Speed
    So I took a look through this section and found SpeedFan. Thought about how my computer sometimes can gets very hot and can edge on overheating (according to CoreTemp) so I decided to give it a go.
    But it doesn't list my motherboard. I dig some digging and my motherboard is an Intel GL40. So any alternative programs to do a similar goal as SpeedFan?
  2. #2
    Senior Member
    Ultimate x64, home Prem 64
    Local Time: 11:44 AM
    canada
    Re: Fan Speed
    What are you trying to do? That mobo part is for overclocking.
    Speedfan is for possibly controlling the fans.
  3. #3
    ChaosDark's Avatar
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by Patonb View Post
    Trying to reduce overheating. I been monitoring my temperatures with Temp Core and all that and it edges close to overheating on good occasions (Single digits or low teens to TJMax).
  4. #4
    americancritic's Avatar
    Senior Member
    Arizona
    Windows Vista Home Premium 64 bit Sp2
    Local Time: 08:44 AM
    usa us arizona
    Re: Fan Speed
    Hello here are a couple of sites for you to look at.
    Core Temp
    CPUID - System & hardware benchmark, monitoring, reporting
  5. #5
    ChaosDark's Avatar
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by americancritic View Post
    Core Temp
    I currently have tired both of those actually. I am using Core Temp right now to monitor what is up with it. (Typoed it as Temp Core).
    I also deicded to open up the panel covering up the motherboard and bit a bit of cleaning to it. Blew at it and quite a bit of dust came out. I blew at the vents on the side and there was a lot. SO far that has as far as I can see improved the performance of the fan a bit. I'll try more to see what happens.
  6. #6
    Senior Member
    canada
    Re: Fan Speed
    youre not going to use a program to do what you want.
    Youre best option will be a cooler.
  7. #7
    ChaosDark's Avatar
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by ChaosDark View Post
    It seems this did quite a bit of magic. It is sometimes the simpliest of solutions that you overlook and completely disregard that gets results (It is now like ~20 degrees cooler)
  8. #8
    Senior Member
    canada
    Re: Fan Speed
    Yha, i had my acer shutting down because the gopu overheated.
    Cleaning helped it go bye bye.
  9. #9
    Senior Member
    Arizona
    usa us arizona
    Re: Fan Speed
    If you use compressed air do it in short bursts not full out.
Fan Speed problems?
Can you speed up download speed from ISP Tarka Dal General Discussion 2 25 Feb 2009
Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. liturgy Vista General 2 14 Nov 2008
Help! Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. grandmarnier Vista networking & sharing 1 14 Nov 2008
Network speed is half or one third of speed on XP power 3 Vista General 3 10 Apr 2008
How to check your Speed Boost tested memory speed Bob Vista General 0 22 Feb 2007
