Like Patonb said, (hello patonb :D ) The temps look fine. I had a socket P once too, the speed was 1.8GHz and temps at idle were 50c. under full load they were 90-110c. Your laptop should be fine... What do you do on it? I would monitor the temps at full load and post em here. If the temps hit 100c or over then i would start to worry as most chips in computers cant stand heat over that limit. not to mention shortening the lifespan of everything near it. Hope i shed some light on the situation.
HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
Realtek HD Audio
Dell E2311H DVI/VGA 5ms response, Full HD
1920x1080 @ 60Hz
320GB Seagate Barracuda 7200.02 SATA II
Cooler Master Extreme Power Plus 700w
Lian-Li PC-6010 With Side Window
Aywun A4 80mm fan
Logitech K120 Wired Keyboard
Logitech K120 Wired Mouse
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
