CFLORES0552
Dear all...I am a disabled student. My dell vista home premium is great that i've had since 2008. However, sometimes when i turn on my computer i hear what is similar to either a grinding or choke sound running in few second intervals coming from the cpu. As seconds & a minute or so passes it's quiet. I'm not sure if it could be the fan or the motor. Are there any suggestions from the experts out there? In addition, since most of my work is done on my computer, it seems to run either slow or it's just running fast & loud as if the motor is working...it was not like this last year & i maintain my computer by cleaning the disk drives and defraging it, etc. Any suggestions would be most appreciated. Thank you...ccf<!-- google_ad_section_end -->
- DELL/INSPIRION 530S
- INTEL CORE DUO E4500 @2.20GHZ
- 2.00 GB
- 1280 BY1024 PIXELS
