Just letting my friends (actually depends on if you like me) at Vistax64.com know about the home made cooler i made for my graphics card.
EDIT: pictures below.
Materials used: (will differ to other cards)
1X AMD Athlon II Cooler (Aluminium Heatsink, took off fan.)
2X 1/8" 4-40 threaded rods
4X M6 Nuts
4X M4 Washers (small base)
4X M4 (large base)
1X a saw that can cut through metal
Reasons why I am doing this: My HD 6450 1GB was overclocked higher than previously maxed with MSI afterburner and MAX temps in games were 64-72c
The stock Gigabyte cooler w/ fan is small.
Hopefully the NEW home made cooler will do better.
EDIT #2:
Results are pleasing:
I used MSI Kombustor and a 30min stress test to record temps
STOCK HEATSINK PC idle: 52c
HOME MADE
PC idle: 49c (in picture)
STOCK HEATSINK
MSI Kombustor: 72c @ 851/1010
HOME MADE HEATSINK
MSI Kombustor: 57c @ 851/1010 (see picture below)
HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
Realtek HD Audio
Dell E2311H DVI/VGA 5ms response, Full HD
1920x1080 @ 60Hz
320GB Seagate Barracuda 7200.02 SATA II
Cooler Master Extreme Power Plus 700w
Lian-Li PC-6010 With Side Window
Aywun A4 80mm fan
Logitech K120 Wired Keyboard
Logitech K120 Wired Mouse
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
Thomson A/B/G/N Router
LiteON CD/DVD Player
GAME PERFORMANCE:
Battlefield 3: 41 FPS High 1x AA @ 1280x720
Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
Counter Strike Source (and other Valve games):
300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Realtek HD Audio
1920x1080 @ 60Hz
Aywun A4 80mm fan
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
GAME PERFORMANCE:
Indeed, although it could use a bit more touch up's like shave the rods down at the back of the cards, 1 rod hits my northbridge heatsink and might be moving heat onto-off both heatsinks :O
Realtek HD Audio
1920x1080 @ 60Hz
Aywun A4 80mm fan
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
GAME PERFORMANCE:
Realtek HD Audio
1920x1080 @ 60Hz
Aywun A4 80mm fan
802.11B/G/N 17Mb/s
AMD Catalyst 12.6
GAME PERFORMANCE:
