Program to tell temperature of components?
  1. #11
    Senior Member
    Ultimate x64, home Prem 64
    Local Time: 04:52 AM
    canada
    Re: Program to tell temperature of components?
    Both are important, and they should both be near the same under load. A 4C diffference is completely normal. Ive seen a 8C differance before.
    The annoyance of a dual core, is the back ground process can warm up a core at idle, makuing it look like things are amiss.
    D/l prime95 or inteol burn test to stress your cpu to get an accurate 100% load number.
    Download IntelBurnTest 2.53 Free - Stress your computer to find out how stable it is - Softpedia
    |MG| Prime95 27.2 Build 1 Download
  2. #12
    ProjectDan35's Avatar
    Senior Member
    Rhode Island
    Vista Home Basic, 32bit, Service Pack 2
    Local Time: 03:52 AM
    usa us rhode island
      Thread Starter
    This is what I got now on the Stock CPU.
  3. #13
    townsbg's Avatar
    ~~тσωηsвg~~
    US of A
    Mac OS X 10.8
    usa
    21C with stock cooling? I wouldn't believe that unless possibly with water cooling. I use CPU-Z.
  4. #14
    Senior Member
    Rhode Island
    usa us rhode island
      Thread Starter
    Quote Originally Posted by townsbg View Post
    That's what It says.............
    Cpu Z doesn't show temp?..
    I mean, stock cooling, There's a 120mm fan from the PSU blowing in there, there's a 100mm exhaust fan on the back blowing out. Maybe it's true? PSU has it's own fan - heatsink stock.
  5. #15
    Senior Member
    canada
    Whats your room temperature?
    21C is low, but its chilly in Rhode I right now.
  6. #16
    Senior Member
    Rhode Island
    usa us rhode island
      Thread Starter
    Quote Originally Posted by Patonb View Post
    It's 69.2 F in my room.
  7. #17
    Senior Member
    canada
    AT 62 ~ 16-17C It is quite possible.
  8. #18
    Senior Member
    Rhode Island
    usa us rhode island
      Thread Starter
    I don't see why it wouldn't be right. It's just sitting idle with 11 Google Chrome tabs open. That's it.
  9. #19
    Senior Member
    Rhode Island
    usa us rhode island
      Thread Starter
    I downloaded SPECCY, this is what it shows. For some reason the CPU temp isn't showing?
  10. #20
    Senior Member
    canada
    Quote Originally Posted by ProjectDan35 View Post
    Um, thats what I said too
Page 2 of 8 FirstFirst 1234 ... LastLast
Program to tell temperature of components? problems?
Solved CPU Temperature! zombifier Overclocking & Cooling 3 24 Jun 2010
CPU Temperature Dino Vista General 9 11 Oct 2009
Processor Temperature CB Vista hardware & devices 6 01 May 2007
CPU Temperature Program for Vista Brian Vista General 23 30 Dec 2006
Fan and Temperature Monitoring program Vista on for Intel iMAC Donald McDaniel Vista installation & setup 0 25 Sep 2006
