System Manufacturer/Model Number Emachine ET 1161-05 OS Vista Home Basic. 32 bit SP 2 CPU AMD Athlon 64 LE-1640 Motherboard eMachines MCP61PM-GM (Socket AM2 ) Memory 2.00 GB Dual-Channel DDR2 @ 387MHz (6-6-6-18) Graphics Card Acer E181H (1280x768@60Hz) 128MB GeForce 6150SE nForce 430 ( Sound Card Realtek High Definition Audio Monitor(s) Displays Name Acer E181H on NVIDIA GeForce 6150SE nForce 430 Screen Resolution 1280x768 pixels
Keyboard Standard PS/2 Keyboard Mouse PS/2 Compatible Mouse PSU MCP61PM-GM 9000 NVIDIA Chipset Model MCP61 Chipset Revisio Case Tower Cooling Fan Speed 1247 RPM Hard Drives ST316081 5AS SCSI Disk Device Internet Speed http://www.speedtest.net/result/1538974261.png
System Manufacturer/Model Number Toshiba Satellite Pro A200 OS Vista Home Premium 32bit.SP2 CPU Intel Pentium T2080 code name Yonah Motherboard Capel Valley (napa)CRB PSAF1A-003002 Memory Kingston DDR2-2GB Graphics Card none 945 chipset 256MB Memory Sound Card Realtek Monitor(s) Displays 17 inch Screen Resolution 1280 x 800
Hard Drives 1 x 120GB Hitachi 5400rmp
1 x 650GB Western Digital Elements 5400rpm Internet Speed Fast Telstra Clear 10Mb download speed 2Mb upload speed Other Info Weakest part of my computer is the graphics chipset.
Only ever used a laptop.
New Mexico, USA!
Vista Home Premium x64, with others on VMware for fun!
Local Time: 02:57 PM
Re: Program to tell temperature of components?
Just wanted to throw in that I've heard some CPU's don't have a temp gauge that your system can access. Now, I imaging ALL CPU's will have some sort of temperature control mechanism that shuts it off if it gets too hot, but these mechanisms can be connected solely to the CPU and not provide any info to your system. I got the impression that this case is pretty rare (and more likely to be a problem with older systems) but that might explain why you aren't getting any temp feedback.
System Manufacturer/Model Number Dell Inspiron 1545 OS Vista Home Premium x64, with others on VMware for fun! CPU Intel Core 2 Duo T6400 @ 2.00 GHz Motherboard DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05 Memory 4 GB Graphics Card Mobile Intel(R) 4 Series Express Chipset Family Sound Card IDT High Definition Audio CODEC Monitor(s) Displays Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm) Screen Resolution 1366x768
Keyboard Built in Mouse Touchpad, + Logitech wireless mouse (USB) Cooling Single built in fan Hard Drives Internal 320 GB
Portable 320 GB used for separate storage of media, plugged into USB port as needed. Internet Speed ~150 kilobytes/sec DL Other Info Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
