Vista - Suddenly silent
Old 11-04-2007   #1 (permalink)
Windows Vista 64
Suddenly silent
The sound was workibng fine on my machine until today...I've checked the connections, checked the properties in control panel, checked the volume levels on the system and in windows media player - and I don;t know what else to check. Any suggestions?
Old 11-04-2007   #2 (permalink)
Windows Vista 64
Re: Suddenly silent
Just thought - the only thing I can think of that I've done since I last used th ecomputer with sound was installing Avast virus protector. Could a virus protection program mess with sound?
Old 11-04-2007   #3 (permalink)
Windows Vista Home Premium x64 SP1
Re: Suddenly silent
Restart the computer. I've had that happen from time to time. A restart always seems to bring it back. No reason why, as far as I know.
Old 11-04-2007   #4 (permalink)
Windows Vista 64
Re: Suddenly silent
Tried that, doesn't fix it. I think it might be something to do with windows media player; I've been testing it with a music CD, and a couple of times it's said that it's experiencing an error and has to close.
Old 11-04-2007   #5 (permalink)
Windows Vista 64
Re: Suddenly silent
I've had the same warning pop up again: "Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file."
Does that mean anything to anyone? It was working fine yesterday...
Old 11-04-2007   #6 (permalink)
Vista Ultimatex64
Re: Suddenly silent
Lost sound on my Dell E1705 with non factory installed Windows Vista Ultimate 32bit. Everything worked fine for a long time until I installed 4 GB of memory. I went to Dell's site and dounloaded updated Vista drivers for the soundcard and flashed the motherboard. Don't know if that was the reason for the problem, but it fixed it. BTW, be sure you check for the correct sound provider or mother board install in your system. I didn't and even bought an upgrade from Creative thinking that was what was on my system. It wasn't and finally realized mine was the other choice. Dounloaded that one and everything worked fine.
Old 11-04-2007   #7 (permalink)
Windows Vista 64
Re: Suddenly silent
Everything should be up to date; the computer was built only a couple of weeks ago, and everything was checked to make sure it was cpmpatible.
Old 11-04-2007   #8 (permalink)
Windows Vista 64
Re: Suddenly silent
...and it's started working again. I disabled the sound card and then enabled it again - seems to have done the trick. Cheers for the suggestions
Silent Hunter 4 Vista Games
silent hunter 3 Vista Games
My computer has gone silent! Vista music pictures video
Silent User Vista General
Silent Hunter 3 Vista Games
