| Vista Home Premium 32bit | Connecting External Synthesizer to USB Port on Intel D Motherboard After changing the SoundCard to SB Audigy for Vista compatibility, I have lost the gameport on the SounCard which I was using earlier for MIDI-IN & MIDI-OUT to my external synthesizer, through a connector having two 5-pin DIN plugs. Since Gameports and MIDI ports are changing to USB, I am wondering if I could connect my synsthesizer to the USB port on the motherboard and if I can, would I need to hunt for a Vista-compatible MIDI driver or whether the RealTech drivers provided along with the motherboard would have the MIDI handling capability. Is the USB port to two 5-pin DIN plugs connector a standard one I can buy in a computer shop? P. Jayant |
| how can i use rear line-in port for rear speaker on Intel D945GCPE motherboard | Sound & Audio | |||
| Connecting External Synthesizer to USB Port on Intel D Motherboard | Vista hardware & devices | |||
| Connector for External Synthesizer to Pentium D motherboard | Sound & Audio | |||
| How to connect External Synthesizer with 2 pin DIN plugs for MIDI-IN & MIDI-OUT | Vista hardware & devices | |||
| Intel DG33TL Motherboard - Won't stay asleep? | Vista installation & setup | |||
