Missing relative volume bar
gonotebook
For no reason, when I adjust the volume bar the meter that shows the relative level of the volume no longer appears. I did not intentionally turn it off and would like it back on. How do I get the relative volume meter to reappear?
Thank You
I now have this problem too. The volume level will adjust fine, it's just that the Green and Gray bars no longer appear? Does anyone have any ideas on how to get them back...?
-Thanks
*Update*
I created another User account, and the volume control bars are working fine in it. So it looks like the issue isn't system wide......
Any help would be greatly appreciated.
-Thanks
Thank You
-Thanks
Hi to you both,
Right click on the notification area, select properties, Put a tick in the loudspeaker box, and click on save.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Standard
    Easy Line Laser Mouse
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
Thank You
-Thanks
Hi to you both,
I hope this helps
Pooch
When I right-click and go to Properties, I don't see a "loudspeaker" box. I see Icons and System Icons ("Volume" is a box there). That just toggles the main volume icon in the system tray, not the green and gray bars?
-Thanks
-Thanks
Yes Thats right it has just gotten badly translated :) (my system is in German)
Then tell me more about these Grey Green bars because I only have the normal volume control better still give me a list with your Motherboard and Sound device details
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Motherboard - ASUS M2N32-SLI Deluxe Wireless Edition
Sound Card - Creative Sound Blaster X-Fi Fatal1ty FPS
O/S - Windows Vista x64 SP2 v.113
In Vista, you have the standard Speaker icon. It will show 0-3 green "waves" on the right side, depending on the volume level. It will also have a red "no" symbol on it when the volume is muted. That speaker icon is working fine, and it has nothing to do with the issue at hand.
The problem is... when you left-click on the speaker icon, the volume "panel" will appear. It has the volume control "slider" on it. When you manually adjust the "slider", it will do 2 things. First, it will give a "ding" to show you the current audio level you just set. And second, it will "flash" 2 bars. A 'green' bar and a 'gray' bar. The bars show you the current audio level and the audio limit. These bars are now missing, and no longer appear. I have reinstalled my sound drivers several times. I have updated to SP2 (to see if it would "fix" the problem). I have checked for policies in the registry. Nothing seems to work. As I stated above, I created a new user account on this computer (just as a test) and the volume bars work fine. So it is something that got "disabled/turned off" with my main user account. I have been trying to find a solution to this problem for months. I have searched everywhere and can't find any info about it...
NOTE - I have tried 3 different sound drivers and I have tried removing all sound devices. The problem seems to be with "Windows" and not the sound drivers/devices.
-Thanks
I get the sound effects. When I adjust the volume I get a scale on the left 0-100 the only other thing is a vertical green grey level bar that shows when (for example) music is playing I presume this is what you mean.
If it is missing by you I really don't know how to get it back sorry
To be honest though I wouldn't miss it either so what is so important about it??
Pooch
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
Going out on a Limb...but do you per chance have oen of those Media Keyboard type with volum controls and extra buttons?
