Vista - Realtek jack detetion issues and no sound
Old 02-02-2008   #1 (permalink)
Vista Home Premium
I found these forums while I was looking for a solution to my problem so hopefully one of you guys can help out some.
I'm getting no sound out of my speakers(2.1), when I plug them into the green jack on the rear panel it says that I have plugged in the pink and black jacks, but neither of those are plugged in. I've spent hours on the phone with HP and looking on the internet but i can't find any solutions. I've updated every possible driver. Every now and then I can somehow get sound by messing with settings and restarting or doing a power drain or a million other things, but as soon as I restart the computer they aren't working again, and the same solution never seems to work twice. Also, when the sound does work, it still says the black and pink are plugged in.
No sound from the head phone jack on the front panel either.
I hope somebody knows what the hell is going on.
Old 02-03-2008   #2 (permalink)
Vista Home Premium
Re: Realtek jack detetion issues and no sound
ok so i lied a little bit, i figured out that there is some sound...but with the system and speaker volume all the way up it's still almost nothing
Old 02-09-2008   #3 (permalink)
Vista Home Premium x64
I am having the same issue here. I have Home Premium x64 on a nVidia nForce 680i mobo with Realtek HD audio. I have the R1.86 patch installed.
After I finish installing the patch, my 2.1 speakers work fine, but as soon as I restart the speakers are not detected. I have tried uninstalling, reinstalling, reinstalling with vista's compatibility mode reinstall option, but no joy. It only works the one time before I restart.
The Audio Devices panel shows the speakers are not found:
Any help with this would be much appreciated.
EDIT: After looking a little more I found this post: http://www.vistax64.com/vista-hardware-devices/62726-realtek-high-definition-audio-problem.html This solves the problem.
Old 02-10-2008   #4 (permalink)
Vista Home Premium
i can't figure out how to get the jack detection to work right but i did figure out how to get sound. i have to unplug the speaker from the back and plug into the headphone jack in the front, then plug it into the back again. after that they work perfectly until i restart and i just do it again. hope that works for you.
Old 08-07-2008   #5 (permalink)
home premium
HI
I have got the same problem I was jsut on my computer listening to music then i moved the table which my computer was on and they cable for the sound ( which is also my telly) and i dont no what one to put it on my computer could anyone possibly help i know that my headphones work in the frontbut nothing works when i try it in the back and I have got the right cable because it has worked before and the right connector on the back of my telly so could anyone help (WHICH ONE TO I PUT IT IN AND WHAT IS THE RIGHT DEVICE DO I PUT IT AS)
Realtek jack detection problems Sound & Audio
realtek audio jack mixup Sound & Audio
Realtek HD Drivers Problem - Jack Sensing Sound & Audio
Realtek AC97 and Windows Vista Sound Issues. Vista hardware & devices
Realtek only sees headphone jack?? Vista hardware & devices
